Old 03-01-2008, 07:05 PM
metalworkz's Avatar
metalworkz metalworkz is offline
metalworkz is on a distinguished road
Hi Woffler,
If you raise the Z to say 2.0 at the tool change then when you change the tool you can use a 1-2-3 block to make sure the tool is set to the same Z zero position with the 2" side of the block. If you use the Goto command (button with arrow below tool change in CAM) there are several otions one is the Retract which allows you ti input the Z height to retract the Z axis to. There is also the GoHome option and the GoTo option in that GoTo popup. I usually retract my Z to 2" and it allows for easy tool change and checking to zero the tool before restarting the program. I'm sure there are other methods to do this but this is what I have been doing. Hope this helps in some way until someone post another method.
Regards,
Regards,
Wes
