Well have you tried a smaller distance for the lead in lead out.
Also if you want cutter comp being G41 or G42 you will need to change it to Wear if you are running MC9 or higher.
if you are using 9.1 you can get the tool to comp before entrying the hole if you want say at the rapid plane.
Now did you want it to helix in to the hole following the profile?
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management)
Cadcam
Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng) |
