  #12   Ban this user!
Old 03-01-2008, 05:06 PM
Oldmanandhistoy Oldmanandhistoy is offline
Oldmanandhistoy is on a distinguished road
Originally Posted by BobWarfield View Post
No, I think that's exactly right. That's why I look at the 1" and larger figure.
I don't know what mil you have, so I can't advise whether you would have use for a bigger end mill. Which model is it?
RE number of degrees of positive rake, that's going to be very application specific. You can get the rake from either the way the insert is mounted or the insert itself. Very often it is a combination.
I'd ask the seller to point you to the manufacturer's web page for the end mill. Take a look there and just see if positive rake is mentioned. For example, here is the Lovejoy facemill page I mentioned:
http://www.lovejoytool.com/f225.htm
It mentions both the positive rake and goes on to say, "ideal for small and light duty machines in general purpose applications." That's us home guys! Most of the manufacturers will make such a mention.
Your 12L14 leaded steel should be very easy to machine, BTW. You won't need the last word in cutter technology to do it. Nevertheless, eventually you'll want to cut something else.
And I would definitely not discourage carbide on these small machines. It works great.
Best,
BW
My Mill http://www.chesteruk.net/store/century_vs_mill.htm but I am seriously considering a better machine.
I will ask for the manufactures website and see what comes up. Seems to be a good price after a little further searching but that may be reflected in quality.
I’m a wood machinist by trade and know what difference quality tooling can make especially on lighter machines so believe the same would be for milling metals.
Thanks again,
John
