Old 07-20-2004, 10:15 AM
elalto elalto is offline
elalto is on a distinguished road
Question On Mach1 motor set-up
Hi All,
I just installed Mach1 and will be giving it a try, however, I have a question on the motor tunning. My motors are 1.8 degree step angle which means 200 steps per rev right? my control board is set to microstep at 1/8 step so that means that I have 1600 steps per rev, right? which then means that since my TPI is 4, I need to go 6400 steps per inch, right so far?
The tuning box in Mach1 asks for steps per unit, I am using inches as my units so.. am I correct in putting 6400 in this box or should I put the 1600 per rev number in there.. or should I use the 200 steps per rev relative to the motor's step angle?
Appreciate any help I can get...
Thanks,
Marcos (elalto)
