Old 02-27-2008, 03:54 PM
philserveng philserveng is offline
philserveng is on a distinguished road
First, I would check all the connectors to/from the cnc control, then if you have an electrical drawing, use a multimeter to check out voltage along the estop chain circuit. Make sure the xyz axis are not sitting on an overtravel switch or a switch is not stuck down. Finally, are you sure the supply voltage and polarity is correct?
