use the dropdowns to create your machining stratagies ,you get more options
in the cad side use the group number option in the contour/profile box to "group" similar
depth parts ,this way in cam you can select a contour to machine then in the options tab you can select "machine all contours with the same group number" saves a lot of time ,be aware tho that if these parts are differing depths it will machine all to the
depth of the selected contour ,hence group similar contours on 1 layer |
