ger21- do you have a source for a 10amp power supply? Most of the 48v supplies i've found seem to peak at around 8amps. What is an unregulated power supply? Those will definitely work but they are twice as expensive. Ok so i took some pics of the slides i have.
-pic 1- 30mm open block slide and 48" 30mm hardened shaft
-pic 2- same
-pic 3- 16mm bushing and 15" shaft with tapped ends
-pic 4- same
As far as the leadscrews, what do you guys suggest? I was thinking 1/2" 10 5 start like i said, but am also considering roton ballscrews? Suggestions? Like everyone i'm trying to stay as low as possible on the price but with good results. Well gotta start drawing this thing up now, thanks for any comments. |
