Old 02-23-2008, 07:28 AM
stevehuckss396's Avatar
stevehuckss396 stevehuckss396 is offline
stevehuckss396 is on a distinguished road
Originally Posted by vadimvc View Post
Well I tried to make my last response general but I'll go into specifics about the reason behind titanium. It is for a weapon for a one pound robot. I need the weapon to be as large as possible but still be able to survive hits. Aluminum doesn't fall into this category as a piece of aluminum would just get immediately destroyed. Titanium will do the job, as will steel however steel is far heavier meaning the weapon must be significantly smaller. I found a nice chunk of Grade 5 Titanium on ebay for cheap and so now I'm trying to work on the next step of the process on how to actually cut it. Thanks for all the suggestions, I'll hopefully pick something out soon.
You dont owe me an explanation. If you want to make something out of titanium, than that is what you want to use. I made a tool for a few people at work that cannot be purchased in stores. All were aluminum except one guy requested brass. Well brass worked great and looked great. Now there is no way I was going to let his be cooler than mine so I made one for myself in of course, titanium. Did it NEED to be titanium? No. Sometimes it's not about the bare minimum needed for production. For people like me, this is a hobby and there are reasons not considered by "production" guys like COOL FACTOR. The tool i made is the only one there is, the only one there ever will be, and i have already turned down enough money for it to cover the cost of all the expensive tools plus.
I'm not a machinest so all i can offer is this.
Solid carbide endmills and drill bits at low speed and take a good bite. Dont be afraid to feed some material to the cutter. When i tapped a hole i used a new HSS 2 flute tap and alot of tap magic. Cutting was easier than i thought it would be.
