Old 07-18-2004, 09:07 AM
Bloy2004's Avatar
Bloy2004 Bloy2004 is online now
Fumbling Machinist
Bloy2004 is on a distinguished road
hmmm ...I think you have a good 115 AC power source when you only have 230-240AC available.
When you rectify that you will have about160VDC. ...with only 150VA rating, you also might/will need a transformer with higher amp ratings.
If you apply 115VAC to the primary 240VAC, you will be outputting roughly 57VAC, rectified would be 79VDC(or so), but very limited in amps. I don't know your full needs yet, but I suspect this transformer will fall short of them.
..anyone. correct me if my overview is wrong.
Shoptask rebuild:
http://www.cnczone.com/forums/showthread.php?t=2139
Home built gantry router:
http://www.cnczone.com/forums/showthread.php?t=5049
