I am learning to use bobcad version 21. This is my first 3d drawing and cadcam software so im still on the bunny hill.
I am having trouble with getting the generated program to make a finish pass which follows the contours on X and Y. When using the planar tool path it runs across on X untill it reaches a contour and then pulls up on z. It doesnt arc around the countour or follow it at all to blend the seperate cuts together. It leaves a space of material where the tool doesnt touch from one pass to the next. It will however follow a contour on Z axis and leave a nice smooth radius.
Can anyone help me out here? There has to be a way to do it i just dont know how. Need to create a finish pass or simply blend it together while its roughing it. |
