I'm sure it's me this time. | | Ok, we had the one part cut out and it looked really nice. The angles had clean cuts the radius looked great, etc. etc. Very happy with the way it cut.
The next little Item on the agenda, is a Key Chain.
I cut one out using MeshCam, but it looks like mess. It went right though a couple of areas for some unknown reason. Than the finish pass was moving up and down in Z around the entire part which made the sides and top look funny.
Anyway, The whole thing is only 0.20" think, with two cut of 0.10 each.
Here's what I have so far:
CON_0 Is the outside Circle
CON_1 is the top with the points, this should be cut from 0.0 to -0.1
CON_2 is the bottom Cross, this should be cut from -0.1 to -0.2
I have gotten it to profile CON_1, but than it won't allow me to Clear the area?
I have also gotten to profile CON_2, but cuts though CON_1, and won't clear the area.
I'm sure it a me though and setting up the CAM to do it.
Any advice?
Smitty |
