As a "rule", no you do not have to use the Contour creation function. It is suggested however, so that you can control the direction of the cutter around wireframe geometry.
Yes, it does combine all of the selected entities, in a contiguous chain, into make one selectable entity, which then allows the user more control over the direction of the cut.
Regards |
