  #12
Old 02-19-2008, 09:14 PM
machintek machintek is offline
Moderator
machintek is on a distinguished road
It has been a long time. Using the ALT key and P (Ithink) you can get into PROCOMM set up. Nothing strange here. 8 data bits, 2 stop bits, Xon Xoff enabled, no parity. The proper cable. BAUD rate to match. Start low like 1200.
Here is what drove me crazy until i figured it out. Press page down to start a down load to the PC. here you need the entire path of where you want to store it with the file name following DOS rules. IE: C:\temp\test.txt
Go to machine and go to load, to remote, select the program., and execute.
If I am in front of a machine, it comes back to me pretty quick. I am not in front of a machine so this is a good start.
George
