thanks to all for the info. I don't know the name of the exact program he's using, it never came up. I do know i have a copy of procomm I can send him. Do you remember the process you used to send from the CNC to the PC Machintek? I ask because you are, or did, also use port A like us. We can get it to load to the CNC just fine but we are not getting the CNC to PC part to work. If you could remember the key sequence on the CNC to send then that would be beyond fantastic. I think the port B sequence is pretty straight forward by going to Setup Load, send to remote option, but the Port A sequence i think may be different. We can work on the multiple program issue later once we get the two-way communication figured out. |
