Originally Posted by zwmaster Hello.
I'm testing this driver from mutoh.
IP-210/IP-220 http://www.mutoh.be/page.aspx/152
2000/XP drv = http://www.mutoh.be/01/MyDocuments/xp-nt.exe
It should work with all old plotters, also iP-530.
And yes I have iP-530.
I test with PCAD (PCB Design prog.), would someone give some feedback on how is working with AutoCAD, ProEngineer etc.?
There are some minor problems with offset (XY zero pos.) and some missing vectors (small lines, dots). I'm not 100% positive it's PCAD's fault, but allmost
BR |
***as you experienced very well, Windows creates a lot of problems in plotting CAD/Cutting/Engraving works.
The problem is that Windows, Plotters and Applications usually don't give good drivers, or they don't give at all for old plotters.
We can offer a solution: a Third Part Product
Those drivers are recommended from HP, Autodesk, Mutoh, etc. and work great with Autocad, Proengineering, Corel Draw, Power Point, Micrografx Designer, EXCELL, Lotus, Word
and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA
Paolo Casella
tel. ++39 0182 660 210
fax ++39 0182 660 180
www.paolocasella.it
---> plotter driver and ----->click on english flag
