I sort of figured space must be an issue. Other than that it just doesn't cost that much more to go bigger. You might want to try & leave 1 end of the table bolt together. That way if you later want to expand to 8' or even longer length it can easily be done.
It sucks not to have enough room for at least a 4 X 8. That way sheets od stock are economical & you don't first either have to have them sheared in 1/2 or cut them down yourself first.
__________________ If it works.....Don't fix it!
