Toto,
You don't have to change the address of the parallel port. You just have to give mach3 (I am assuming that is what you use) the right address. So open mach3, open the tab Config, then click on Port and Pins. Then you'll see an address like 0x378 on the left hand side box. Change it to 0xfee8. Then you should be able to start jogging.
C. |
