Actually It is already possible to either tell an individual axis to go to zero, or set it to zero.
I am not sure if the buttons are in the default setup, or if you have to make the buttons, but you can create them.
I am not sure if a everyone is aware that you can customize your frontend of Mach2 to do many functions or delete the functions that you will never use. In the Mach2 folder there is a little program that allows you to custimise your front end to suit your machine. |
