Hello Command Post.
I am probably not the best to answer this as I am evaluating Mach2 as well.
Have you downloaded the manual as well?...
With Mach 2 there is an additional program called Hot Keys ( in the Mach 2 directory on your hard drive). This program is used to define the keys etc that you can use on a Joystick/emulator etc.
Hope this helps.
cheers |
