  #10
Old 02-14-2008, 02:34 PM
lovebugjunkie's Avatar
lovebugjunkie lovebugjunkie is online now
Gold Member
lovebugjunkie is on a distinguished road
Originally Posted by wcarrothers1 View Post
Just be ware of the direction yours rotates before making up your bracket..hehe Mine happened to spin the oposit way of his motor thus had to be mounted above. Which really worked out better anyway.
But either way a very easy mod. + gives you variable speed built in (if that is how your motor was on) and a on/off switch.
I did have one of those variable speed controls for routers though. Didn't seem to work right on the stock motor though. I don't think it pulled enough current or something as it seemed to work fine with a standard router motor.
b.
I was thinking of picking up one the router motor controllers, thanks for the heads up, saved me a few $$.
I have not ordered from they yet, but when I get the wolfgang back form having a mount made I thought I would try them, will also check out your suggestion for bits.
george
