  #12
Old 02-14-2008, 07:19 AM
DareBee's Avatar
DareBee DareBee is offline
Monkeywrench Technician
DareBee is on a distinguished road
I connect to mine using a "handshake cable". If I remember correctly it is because Mohit (Fagor) provided the electrical connection defining such.
This same cable also works my 94 Fadal and my 81 Sodick.
Kiwi and I share the same experience. My machine had a 25 pin connector attached to Fagor's 9 Pin. The 25 pin WAS wired wrong. I rewired it and I have used the 25 pin with no issues.
I use Fagor's version of WinDNC and I had to set the baud rate very high or comm would not work.
Theoretically I could use a "straight through" cable if I rewired the machine builders "scab" cable into a crossover configuration.
www.integratedmechanical.ca
