080213-2227 EST USA
cam1:
Now that you have provided a Fagor circuit diagram there is some useful information.
Since Fagor is using a 9 pin RS232 connector with the same definitions as as a 9 pin PC connector, and since the most likely connector on most moderately new, last 20 years, PCs is a 9 pin connector, then it is not a straight thru cable defined by pin X to pin X. Furthermore, Fagor shows a cable for use with software handshake.
This is why a more complete definition of a cable is important.
I see too many comments like "do this ---- " and you are "good to go." with inadequate supporting evidence of why.
