Old 02-13-2008, 01:15 AM
juliancrouch juliancrouch is offline
juliancrouch is on a distinguished road
I really should probably not be tossing my 2cents in here, as I have thought about asking these questions.
However, this is what my 2+2=4 brain could come up with.
You can secure your work with a clamping kit directly into the threaded holes, if they happen to be where you need em. You can use your clamps to pass through the block, to secure your work, then toss it in a vise for odd shapes that would normally not line up with t slots. You can secure your work with the threaded holes, then pass though the non threaded holes to secure your work+block to the t slots for milling?
plus what snipe said, you can drill into the negative space, and since they are square, you can use em as squares. JOY
cheers.
