  #12   Ban this user!
Old 02-13-2008, 12:03 AM
juliancrouch juliancrouch is offline
juliancrouch is on a distinguished road
Originally Posted by under-dog View Post
Is the plans for the master pattern to be stainless? If so why?
Yes, for now I think the final product will be out of stainless and copper (it has some copper parts, hence the sealant question. Later on if it looks nice I may play with using ti for this shape ring (right now I have about 6 or so designs I am sitting on that deal with this basic ring style). However before I ever even get to the stainless I plan to practice it on a piece of AL, just to get used to cuts and machine, as this is one of the first projects when I get the new mill.
Hard to carve, hard to polish hard to solder to.
Yes it is all of these things, but for some reason I have always been attracted to the rugged/hardware look of stainless jewelry (rings and pendents), so while I have the time I thought I might make a line of it.
Or are you planning on one offing these things on the mill?
For now it may be one offing, if everything goes according to plan over the next few months I may do a "common" (if there was such a thing) run of sizes in it, and the others I mentioned.
So what lacquer did you use?
As for what you said Mike, I will be doing it manually, but, I kinda figured on that procedure for making it, but I like the idea of making a fixture just for bolting it to the table, that will be used.
Also, got one more fancy shmancy question for you guys, I know, when will it end, but is it blasphemy to square stock on a lathe, or more specifically can you part pieces off of square stock with a cut off tool? I have done it on wood lathes, but this is a whole different beast. For that matter, is it even safe/possible to turn any square piece down to a cylinder on a lathe?
