Well I'm getting close now everyone. I now have the table set in place and all leveled up. I'm just waiting for the water pan to get broken up, and then it will get the angle and flat bars for supporting the material. I was working at setting the gearlash on the main X axis rack today and was flustrated with how hard it was to carefully move the bracket up or down without having it just drop into the rack. Even with the 5/16" bolts just snug it was hard to adjust the drive gear up and down. I made a little 1/4" by 1" Flatbar bracket,and drilled and taped it for a 10X32 screw to adjust the up down movement of the bracket. It works perfectly. With the bolts just snug you can fine tune the drive gear bracket up or down and be in full controll the whole time. I also tacked a 3" piece of 1/4"X1/4" square bar along the back edge of the bracket so it will slide up and down without rocking while adjusting things.I'm sure this will come in handy when I inevitabley have to fine tune it in the future. I think the pictures will be self'explanitory. I mounted the Bugo torch mount to one side of the trolly so that in the future I can mount the plazma torch holder on the other side.
I loaded all the software on both computers tonight and hope to actually get things hooked up tomorrow for a trial run around the table. I will let you know how things go tomorrow. Thanks |
