Well I've been meaning to try CamBam out, so I downloaded and installed. I created a .dxf file and opened it in CB (CamBam), selected a profile cut, generated tool path, created a gcode file, typed a name in the dialog box that I wanted to call the gcode file.
I did search of my hard drive for .tap extensions.... nothin'
Did search of my hard drive for .nc extensions....... nothin'
Did search of my hard drive for the name that I gave it when I generated the gcode.... There it was in the same directory that the .dxf file was that I opened in CB
CB doesn't automatically add the .tap or .nc entension.........
So look in the same directory as the DXF file that you opened in CB
Hope this helps some,
Jack
__________________ Walking is highly over-rated
Reason: fingers slower then my mind
