OK
Another tip would be for face milling with a cutter whos diameter is greater than the material size.
I have found extremely simplistic toolpath by drawing a region right down the middle of the part with each end of the region extended past the stock slightly greater than the distance of half the cutter. Create your toolpath by using the engrave feature with the on edge function enabled. Tool wil just go back and forth plunging the set distance outside of each end of the part.
Quite simple...very effective. |
