Well after about three more hours of just getting the contours outlined correctly and few other areas. I may have figured the first steps out. There still seem to be some issues in how a files is opened.
CAD - Opened it and it stayed in Inches
CAM - Opened it and it changed to MM
Figured that out, maybe, we'll see.
Had to remove all the drawing lines from the templated,, leaving only the lines I wanted.
Attempted to set the NC at 0,0,0 not sure if that is being picked up yet.
Made the two contours, One that goes around the outside of the part. The other one should go around the INSIDE of the Hole. Couldn't find where to change that so It became a Pocket instead.
I may be on the right, but slow track now.
The video should be here some time today. This should show me if I'm doing it correctly.
Smitty |
