For purposes listed, tool wear and size ajustment, Cutter Comp is a wonderful blessing. You just have to understand how it works on your machine. As far as reposting goes, it takes more time to repost than it does to change an offset radius at the control. In OneCnc you can repost rather quickly, but it still takes more time. Approach, depart, path overlap are the things to be concerned about with cutter comp. If you know how to do it you're miles ahead of most. Everyone I know hates cutter comp.. I guess I would say get to know your machines and how they act when given the command. You may find out how wonderfull cutter comp is.
Ken |
