Thread: Need Help! HAAS Radius error
Old 02-05-2008, 06:44 PM
Geof Geof is offline
It could be that the arc you need goes past 180 degrees. When you are using R for G02/G03 and the arc is larger than 180 degrees the R value has to be negative; if it is less than 180 degrees it is positive.
