Hi Wes,
Changing the Modal to absolute seems to work, but I'm still not sure. The circle is much smaller, but appears too far away from the rectangle. I ran the program to find the actual cuts are MUCH smaller than what my drawings called for. The two shapes blended into each other, both way smaller than they should have been.Programming was done in DCam, drawn with scaling intended 1.8= 1.8". After posting in Mach 3, the control point doesn't move 1.8", but more like .18"!
The M3 DRO is a multiple of 10 different than my programming. Should I re-write to match the DRO scale of 10.000= 1.0" of control point travel? Is it always going to be like this? As you can tell, I am new to this and appreciate any help. Thanks
Rick |
