Old 05-27-2003, 12:15 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Not using cutter comp
I hate cutter comp. I'd rather redo my code
Anyway, I was pleased to find out that when editing an operation in OnecncXP, that I could put in a negative amount in the "amount to leave for finish" field, and the new parameters will generate the new path with the desired over-cut. This was a 2d style path I was working with.
