If you've got coolant coming out from the spindle housing, you need to remove the housing, remove and clean the side plates and re-install them with fresh gaskets. (Running the coolant with the nozzles closed will cause these seals to pre-maturely fail.)
'Rekd
__________________ Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
