My V2XT finially comes to life! | | Well almost one year after I took delivery, my V2XT finially came to life this evening.
All axes home smoothly, and so far I've only run into the normal issues covered in previous threads (IE: gummy limit switches)
Here's my only puzzel. My spindle won't start. I'm pretty sure this has some thing to do with the break being active. Also note that my power draw bar will only work in "OUT" mode. This leads me to believe the the brake is on and or the system belives the brake is on.
On the manual units (2J heads) the break lever is pushed away from the operator to actuate, but this unit is a servo or air cylinder actuated.
Can anyone tell me if it should be in the extended position for operation of spindle or extended for braking of the spindle.
Thanks guys, I'm so excited I can hardly sit still
__________________ 9 1/2
B.C.I.T. Machinist CNC |
