Thread: crashware
  #11   Ban this user!
Old 01-31-2008, 09:35 AM
jmcglynn jmcglynn is offline
jmcglynn is on a distinguished road
Originally Posted by tjones View Post
That may be one way but there is another. This one may sound strange as it does not allow for for multiple boundries.
The 'Stock Geometry' located under the 'Milling Stock' is used for a boundry in Z level machining. When set to machine all then it will machine the entire stock defined by the Stock Geometry and ignore any solid area outside of the stock geometry even if selected.
Thanks for the idea, but that doesn't work. I set the stock up as a 1" thick block covering just the area I need to machine to put the rest of it into a fixture. As you can see the z-axis toolpaths completely ignore it.
I'm so frustrated with this software, nothing seems to work properly. Their tech support has been completely unresponsive.
I'm going to look into a refund I think.
