Old 01-28-2008, 08:29 PM
conveyor conveyor is offline
conveyor is on a distinguished road
solution
We solved our problem with the Okuma. It ended up that two of the four studs (that open and close to let the toolholder in and out) were stripped out of the plate which they were threaded into. This kept the spindle closed so that when the tool went to go back up into the spindle it was stopped, thus setting off the alarm. We ended up moving the ATC arm by going into MDI mode using the M59 (bypass interlock) and then M33,M34,M42....etc. to manually move the arm and subpot. Note that when in bypass interlock you need to use the Cycle Start to get the codes to work, not the normal green start button that would normally be used when using MDI. Still aren't sure why the studs were stripped out but they were very simple to make and it was a very easy fix once we figured it all out. Hope this helps someone if they every have the same problem. Thanks
