Thread: Need Help! Just getting into it. . .
Old 01-28-2008, 11:16 AM
ataxy's Avatar
ataxy ataxy is offline
ataxy is on a distinguished road
as brassbuilder said if you have never work on a mill before it is highly recommended that you start by doing manual work this will get you the feeling of the capacity of your machine as these type of machine cannot be operated as you would with a bigger knee mill or even a bigger 700pound rf45 type mill ounce you get use to its capacity you will know how to prepare the code that you will use to operate your small cnc and in turn prevent unwanted wear and breaking of your machine.
cuz remember a cnc does not see that its doing something that it cant it will most of the time try do do it until it breaks you on the other side will see when you crank that handle that you should slow down or take lighter cut
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
