Hi;
Is there a way to stop and restart a program remotely. The
ESC button stops the program then Y/N to restart or terminate the program. One of my projects is a home built Wire EDM. For now the wire EDM is controlled by a programmable controller. I would like to convert it to true CNC. However, the spark voltage needs to be monitored while it is burning. When the voltage drops there is an input to the controller that halts the wire advance untill the voltage increases again, then the wire advance resumes.
Is it possible to pause the Turbocnc software then restart it through some kind of input recieved from the EDM power supply.
Thanks,
Jim |
