Originally Posted by fourperf Hey Geof, how did you manage to get it off the dolly?
Mark |
The dolly was bolted together in sections; two side rails and three cross members. The machine was just lifted up and small blocks put under the jacking screws, the dolly assembled around it with slotted tabs at each jacking screw location and washers and nuts put on the top end of the jacking screw. Then the dolly was jacked up to take the blocks away from the machine. In my barn workshop the reverse was done.
I still have the dolly and have used it for transporting 650lb concrete bloscks out into the backyard for building a retaining wall so it has returned the time I spent making it.
