Old 01-26-2008, 01:09 PM
ataxy's Avatar
ataxy ataxy is offline
ataxy is on a distinguished road
see this is the thing there is no technique per say there is a basis wich you probably learn in the book you bought and then there is how you apply it and this in my point of view is pretty blurry as this will depend on alot of factor such as the machine you use, the material you are working on, the tool you are using (hss vs carbide vs no of flute vs coated or non coated vs quality) and the part you are doing, in the end it all boil down on how you plan on executing your part abd by that i mean the type of fixture you will use to do your job and the sequence of operation (like will you drill befor you mill and ounce you mill the part will you still be able to place the part for the next operation) these are all thing that a book cannot teach you and come from experience and previous error
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
