Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > 3D Scanning
3D Scanning Discuss 3D Scanning software here.
Old 06-26-2009, 12:12 PM
Tristar500's Avatar
Tristar500 is on a distinguished road
tool path from stl file?
Thinking of giving the David laser scanner a try.
Any way to get a tool path off of a stl file?
Is a sentance fragment?
Old 06-26-2009, 01:42 PM
ger21's Avatar
MeshCAM, Vectric's Cut3D, I think CamBam, and pretty much every other higher priced CAM package.
Old 06-28-2009, 08:43 PM
yohudi is on a distinguished road
And of Course the FREE option
You can also do this at zero cost using FreeMill... you will need to edit the post-processor to use the code with mach control software.. or try one of the visualMill based post-processors available at MecSoft.
The VisualMill Mach post-processors are reported to function OK with FreeMill.
I've attached an image showing an .STL I test cut using Mach2 and FreeMill gcode.
Hope this Helps
Danny (aka Yohudi)
What one man can do another man can do..
BitMaps to Models, tutorials and FREE CNC Software http://cnc4free.org
Old 06-28-2009, 10:13 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
STLWork -- not free but has a demo. About $125 as I recall. Seems like you have a range of choices.
BTW -- Let us hear how you like DAVID. Good thinking - ahead. Find a processor for the output --before generating the output!
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 07-22-2009, 09:18 PM
Bradt is on a distinguished road
Vectric Cut 3D works great for this, and it's pretty cheap too! You can download a free trial version. It'll let you post the file, but it adds a watermark until you get a license.
Brad Thomas
My Stuff: Vortech Router, Mach3, Vectric Software
3D tool path!!!!!???? ombosko General CAM Discussion 1 06-03-2009 04:36 AM
Need Help!- can't get the tool path right msn_jrd Mastercam 3 07-21-2008 11:43 AM
3-D TOOL PATH reedmiles BobCad-Cam 15 02-02-2008 08:08 PM
Tool Path cijunet Mastercam 9 11-26-2007 10:17 AM
Tool approach Tool Path Kiwi BobCad-Cam 28 07-05-2007 03:35 AM
