Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > 3D Scanning
3D Scanning Discuss 3D Scanning software here.
Old 05-29-2009, 07:38 AM
DragonXtreme's Avatar
DragonXtreme is on a distinguished road
Exclamation Laser scan to 3D Solid
I was wondering if anyone here was using or know someone that is taking laser scan point clouds and turning them into editable 3D surface/solids. I need something more than STL files.
The programs I have looked at include Rapidform XOR, GeoMagic, CopyCad(now part of Powershape) as well as the Reverse Engineering add-on for Rhino. Cost is a major factor on most of these programs so I am looking for a cheaper alternative to bridge the gap.
Any input would be appreciated.
Thanks,
Architectural - Prototype - Modeling - Mold / FrogMill - ScanTech 3D Laser - ArtCam Pro
Foam - Composites - Hardwood (www.dragonxtreme.com)
Old 05-29-2009, 11:01 AM
dirdim is on a distinguished road
Unless you need to do this frequently, don't bother looking for a software solution as they are as you noted quite pricey. Find a 'service bureau' that does this all the time with those softwares and pay only for the once in a while that you need it.
My firm provides these services everyday and we're in our 15th year of doing just this. Happy to help.
rapid solutions to 3D problems...
www.directdimensions.com
Old 06-02-2009, 04:09 AM
ALoopingIcon is on a distinguished road
If you need a good solution for processing 3D scanned data in order to obtain nice clean 3D meshes you should look at MeshLab
http://meshlab.sourceforge.net
it is an open source tool for mesh processing and 3D scanning data management. It includes tools for aligning range maps, merging them, simplifying, cleaning, etc etc..
it is free and available for Win, Mac and linux.
p.
Old 06-02-2009, 10:00 AM
While MeshLab is open source and a good meshing software, it won't get you to Nurb surfaces, much less feature-based editable ones in a solids CAD package. Only Geomagic and Rapidform have this functionality.
Old 06-02-2009, 02:03 PM
der_fisherman is on a distinguished road
Try Blender 3D, open source, totally free. Very full documentation. Forum and FAQs....In fact everything you need......I would imagine, but being myself a "Newbie", I have not yet needed such a program yet......please test and post your personal findings. Its only a 10MB download, which is good......
You can find it at:-
http://www.blender.org/download/get-blender/
Let me know what you think as I am also considering using it eventually. Its also available in many languages.....
Best wishes.
Old 06-02-2009, 03:52 PM
Thanks for the input.
I will look at the software listed as well as take what people have emailed me providing the conversion services into consideration.
Doing this in house will be more cost effective when I can show my client a working scenario though I will look at outsourceing for the short run to fill the void if I can't jump immediately into a working conversion package.
Old 07-24-2009, 05:24 PM
cadcam's Avatar
Community Director
cadcam is on a distinguished road
I have lazer scaned then brought the point info in to Mastercam using a add-on from Verisurf (http://www.verisurf.com/products_reverse.php )I was able to make a mesh and from the same tool change this into a surface model. I was reverse engeneering a product for a company and then needed to be able to change the surface area to change the flow.
Cadcam
Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng)
Old 09-06-2009, 08:10 PM
D.L D.L is offline
D.L is on a distinguished road
'Mesh to surface' is an option in 'rhinocad', but i could not get it to work properly without freezing the PC.
Old 07-26-2010, 05:57 PM
3DRevEng's Avatar
3DRevEng is on a distinguished road
Mesh to surface option
If you need a cheaper alternative we are resellers of Leios Mesh.
It is easy to generate an auto patch surface within minutes...
We also can scan your parts for you and give you Solidworks parametric models if you need that.
Matthew
www.3dreveng.com
3D Scanning and Reverse Engineering services
Vancouver Canada
Old 08-08-2010, 07:02 AM
an-cadsolutions's Avatar
an-cadsolutions is on a distinguished road
Try VRMesh,
AN-Cadsolutions / VR Mesh
AN-Cadsolutions, Tampere, Finland
http://www.an-cadsolutions.fi
  #11   Ban this user!
Old 08-08-2010, 07:06 AM
try VRMesh
Try VRMesh
  #12   Ban this user!
Old 08-08-2010, 04:29 PM
awerby is on a distinguished road
Getting NURBS surfaces is one thing
Getting parametric solids is another. If you really need the latter, Rapidform XOR is the best software I know of for that. It's certainly not cheap, but I sell it for a discount, if that helps.
Andrew Werby
www.computersculpture.com
Laser engraving of steel and solid carbide JERRIMY Laser Engraving & Cutting Machines 0 02-21-2008 01:03 PM
Laser scan of a neck Meindert Musical Instrument Design & Construction 5 01-25-2008 09:07 PM
i need someone to laser scan a part for me camarogod98 Digitizing and Laser Digitizing 3 02-11-2007 06:56 PM
"DAVID" Free 3D Laser Scan Software! Switcher Digitizing and Laser Digitizing 1 01-26-2007 04:42 PM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 07:25 AM
