yes, your're right!! just see now (i never tried it because directly I work it as a solid to model it)
Surfaces are absolutely enough. In fact, STL files are only surfaces. It "looks" like a solid if it is a watertight STL, but there isn't any definition to the "inside" of such an object - it is just a "zero thickness" skin...
Thank you for your help Mcphill, Vinot and Awerby. I will try this again in the next day all so and report back
Mcphill,
Could you please advise, what settings did you use on the nextengine to scan your face.
Regards
Kel
I did a Quick scan at low resolution, so that I would not need to sit still for too long. I did three scans (one head on, and one from each side at about 30 degrees off center) and stitched them together. Did you go to the Fotki link I posted above? It has more pictures from each step of the process.
Today i scanned a sea shell collected during my last visit to sea side. It was a small shell, need more improvement in scan. however here you go.
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Here's my current project...
As found part:
Scanned in with the NextEngine scanner:
Massaged in RapidWorks and then I played a little in Sculptris, OBJ file displayed here in MeshLab, ready to open in DeskProto to create the toolpaths:
Working on wiring up a 4th axis to my Mikini now, hope to be machining a 2-3x sized part this afternoon - wish me luck! I'll keep ya'll updated...
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
very nice scans!!
Spent the day collecting hardware to get the fourth axis functional (chuck, morse taper adapters, live center, wiring, etc.) and got it functional around 5 pm. Then fired up DeskProto for the first time under license - only used the free demo period about a year ago before today
End result is this code:
Machine is cutting now, will post video and pix later of the roughing stage, I am sure it will need at least one finish pass as well...
a couple of days ago did some scanning of the furniture i purchased. this is Right- side arm carving of the sofa.
First pass complete!
This is in poplar just to try it out, which gets quite fuzzy if machined in certain directions. I have some oak to use "for realz" which should machine (and look) much better... It is much smaller than I was hoping for, but the 4th axis just takes up so much room on the table, I don't have the X-axis length to go too much bigger. I will move it out and do as big a version as I can eventually...
That was done with a 1/4" flat end mill, 1/8" is in the machine now.
And a couple videos if anyone is interested:
Mikini 4th Axis 1 on Vimeo
Mikini 4th Axis 2 on Vimeo
Mikini 4th Axis 3 on Vimeo
Mikini 4th Axis 4 on Vimeo
Mikini 4th Axis 5 on Vimeo
