Page 2 of 6 FirstFirst 12345 ... LastLast
Results 13 to 24 of 65
Thread: Laser scan to 3D Solid
  1. #13
    Registered an-cadsolutions's Avatar
    May 2007
    Finland
    Yes, I follow that. Rapidform is best definetly!!
    It's not cheap but it's worth it. It has powerfull tools to work with scanned data. If You work a lot with scanned data this software pays investment back.
    I love it and I would like to have it.
    I was in June on one university training that software with Roland LPX-600 3D laserscanner.
    AN-Cadsolutions, Tampere, Finland
    http://www.an-cadsolutions.fi
  2. #14
    Nov 2005
    Reverse engineering in a nutshell.
    O.k, I've tried RapidForm/Polyworks/Geomagic and everything in between. I do this for a living. Every project is different, so no one solution works all the time, but here is my input:
    Please keep in mind, scanned surfaces/point clouds and NURBS/CAD surfaces are different. Meshlab is a useful tool for scanned surfaces. There are no free resources for NURBS/CAD surfaces that I have found.
    To generate surfaces for machining/CAD:
    Free solution 1: Use free Rhino3D trial (25 free saves) to generate NURBS surface patches. You have to trace over the mesh or you can drape a patch (like a cloth) over the surface. You can also buy Rhino outright; it's cheap, powerful, and can do a lot (but not all) scan-to-NURBS translations.
    Free solution 2: To create CNC toolpaths straight from scanned meshes, use FreeMill. Easy, free, but limited options.
    Purchase option 1: Buy Leios surfacing/patching license. Definitely the most cost effective tool to get to CAD/NURBS surfaces. The Autosurfacing tool is easy, and can generate surfaces for CNC machining without any brainpower.
    Purchase option 2: Buy RapidForm. It'l cost you a fortune, but it has the best package for reverse engineering mechanical parts and parametric solids. Basically a good fit for recreating parts, as opposed to statues and carvings.
    Or contact me directly, and I can convert for you.
    -Dan
    Global Inspection Solutions
    www.globalinspectionsolutions.com
  3. #15
    Apr 2008
    soain
    I agree with Dan. For me, Meshlab is a must have: can work with scanned data with professional results, first step to get a good scanned and workable object.
    Then you can go to any cad or design software that can handle scanned data (most of them) and generate nurbs objects (less of them).
    Anyway I suggest all you that read this very nice guide-example:
    http://www.rhino3d.com/resources/dis...n&listing=1055
    wich explains perfectly what we are talking about.
    toni
  4. #16
    Dec 2010
    Resurfacing
    There are many different softwares to choose from. Meshlab is a great option to choose.
    Ron
    RnD Precision Imaging
    Welcome to RnD Precision Imaging, Inc
  • #17
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    Rapidform is the best but with high cost..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  • #18
    Dec 2010
    Meshlab
    Meshlab ....free, open source, capable...
  • #19
    Aug 2007
    I'm starting to look around for a company to do some 3d scanning for me. I do custom car parts and some of the ideas coming from my clients are just impossible to create on my cad system. What kind of price range are we looking at to scan a clay model? Can it be converted into an IGES file? I would be using CATIA. This is all new to me
  • #20
    Apr 2004
    Oakland CA USA
    It's pretty hard to say
    from what you've told us here. How big is your clay model? Do you just need a raw scan, or are you trying to regenerate a clean CAD model? The clay itself probably isn't good enough to make a part from, and the scan will not reproduce it perfectly; there's always some loss in translation. An IGES file isn't that hard to produce, but recovering "design intent" takes some expensive software and a skilled operator. Clay models aren't easy to transport either - have you thought about getting a scanner and doing this in-house? I can help with that. It might work better than trying to ship fragile clay models around the country...
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by TGSTP View Post
  • #21
    Aug 2007
    3d scan
    This is all new to me. I do billet aluminum custom car parts for a hobby. My new project is for a 69 charger. The guy has pretty crazy ideas and It's different than what I've done in the past. He wants to have like human features on his car like a hand grasping the mopar logo. Now I have done some crazy stuff in the past, but nothing like this. Now I have a lot of design experience in AutoCad and Catia but human hands would take forever. That is why I was thinking of modeling it and scanning it. If you have any better ideas, I would love to here them. My thought of the quality is that if I could just get an idea, I could just use it as a pattern. Like I said, This is new to me.
  • #22
    Apr 2004
    Oakland CA USA
    That doesn't sound like a typical car part...
    But I might be able to help. If you could show me what position you need the hand in, I could probably scan one and send it to you. That's probably easier than making clay models and shipping them around. $250 should cover that. Milling it is another problem, though...
    Andrew Werby
  • #23
    Registered Pplug's Avatar
    Jan 2007
    Why don't you model the part in poser. It's human modeling software. I've used it before to model human hands holding a key for a coat of arms. Poser is very versatile and people have made several different types of human models to choose from. You cam also import other models into the software for props. Poser can also render out just the hands for import into just about any 3d software package
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
  • #24
    Aug 2007
    I'm not sure thats in the budget. What kind of price range are we talking about for this software?
  • Page 2 of 6 FirstFirst 12345 ... LastLast
    1. Laser engraving of steel and solid carbide
      By JERRIMY in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-21-2008, 01:03 PM
    2. Laser scan of a neck
      By Meindert in forum Musical Instrument Design and Construction
      Last Post: 01-25-2008, 09:07 PM
    3. i need someone to laser scan a part for me
      By camarogod98 in forum Digitizing and Laser Digitizing
      Last Post: 02-11-2007, 06:56 PM
    4. "DAVID" Free 3D Laser Scan Software!
      By Switcher in forum Digitizing and Laser Digitizing
      Last Post: 01-26-2007, 04:42 PM
    5. Which came first, Solid Edge or Solid Works?
      By Arnie in forum General CAM Discussion
      Last Post: 09-15-2004, 07:25 AM
