Results 1 to 6 of 6
Thread: Scanning software
    Jul 2011
    Question Scanning software
    I am looking for a cheaper software, where I can scan a picture , save it as a line drawing, or DXF, and run it on my machine. I am using Biesse works. I am new to this, and have no idea whats out there.
    Apr 2004
    Oakland CA USA
    You might be underthinking this...
    There's a big difference between a "picture", which typically is an array of pixels in different color densities, and a toolpath you can run on your machine. There are various programs that can extract linear vectors from a raster image by looking for the edges of arbitrarily designated color areas, but these will produce extremely complex curves which probably won't correspond to your idea of a line drawing. Even if you start with a line drawing, it will take some work to make a good toolpath from that.
    I'm not familiar with your software package, but I think you first need to find something that will do what you want at all, then start looking for a way to do it cheaper...
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Mar 2003
    Shelby Twp, MI....USA
    Inkscape is free, but getting a good line drawing from a picture is asking a lot. It can be hard to get a good line drawing from a picture of a line drawing.
    But I guess it depends on what your expectations are.
    Nov 2005
    Free vector or gcode from pictures
    You can use inkscape to generate G-code from a picture.
    It isn't super easy, but it is super free, and I was able to create g-code for a 2D CNC laser. It worked incredibly well.
    1: Download inkscape.
    2: Import your picture.
    3: Convert to raster image using the 'potrace' command
    4: Convert to G-Code using 'gcode tools' plugin
    Follow in depth tutorial here:
    EMC Documentation Wiki: InkscapeHowto
    Daniel Ferguson
    3D scanning and Reverse Engineering
    www.globalinspectionsolutions.com
    Portland, Or
    503.470.9306
    Jul 2011
    Line drawings
    Thanks guys, I will have a look at those, I definetely want to scan from a line drawing, as for from a pic,it would be nice, but, you're probably right that there is a lot more involved than I imagine. Like I said before I am GREEN at this.
    Nov 2005
    The process works very well for photos with sharp contrast. I needed to reproduce a hand written signature as a toolpath, and it was a breeze. You could also reproduce blueprints, hand drawings, and other shapes using this technique. Using more complicated photos like buildings, people or animals would take a little more fiddling.
    -Dan
    Global Inspection Solutions
    3D Scanning - -Reverse Engineering - 3D Inspection
    Global Inspection Solutions, 3D Scanning - Reverse Engineering - 3D Inspection
    1. scanning people
      By fred friendly in forum 3D Scanning
      Last Post: 08-11-2011, 11:05 PM
    2. Need A Quote- Laser scanning
      By zcases in forum Employment Opportunity
      Last Post: 10-12-2010, 12:08 AM
    3. scanning to g-code
      By Paul in OK in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-10-2007, 09:30 PM
    4. Is this the way 3d scanning will go ?
      By greybeard in forum Digitizing and Laser Digitizing
      Last Post: 02-15-2007, 12:52 PM
    5. scanning a drawing
      By kenlambert in forum BobCad-Cam
      Last Post: 03-08-2004, 01:47 AM
