Results 1 to 6 of 6
Thread: Scanning information
    Wanna be
    Mar 2004
    I am looking for information regarding purchasing / building a 3 d scanner. It's use will be to scan hand and power tools for our shop and then convert them to some format that can be used by my cad software and then the profiles routed into a board. These will then become story boards for our 5 S work in the shop. A place for everything and everything in its place.
    While the majority of the tools will be less then 24" in lenth, some may be up to 36. I had looked online at the Nextengine product and it seemed ok for the price. I am concerned about it's ability to handle larger items although one could stitch together items it appeared.
    Also read about the David scanner, ad the 3D3 solution. Now I am just confused and not sure what would work best for my application.
    Thoughts and insight would be appreciated.
    Dan
    Check out what I am working on at www.routerbitz.com!
    Apr 2004
    Oakland CA USA
    I don't think you really need a 3d scanner for that
    I'd love to sell you one, don't get me wrong, but if all you need is a profile (which is a 2d cutout as I understand the term) you might be overthinking this particular project. I'd suggest laying the tool in question down on a piece of paper, tracing around it with a magic marker, then photographing the result with a digital camera (make sure you are lined up straight in front of it to avoid distortion).
    Bring that up as a background image in your CAD program, and retrace it with your vector curve tools. This will make a line that your CAM program can follow when routing out the shapes in engraving mode. Of course, if you don't have all that gear, you can achieve pretty much the same result by tracing directly onto the plywood board and following the line with a sabre-saw.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by Hack View Post
    Dan
    Wanna be
    Mar 2004
    Looking for a little more then that
    I have traced the tool outline onto graph paper and then drew them up in CAD using the grids in my cad program to match the graph paper. This allowed me to get them pretty close but I would like to do better. What you suggest sounds plausible (I have never tried it) and should be quicker.
    What I know however is that I would like to think in terms of 3d. I would like to provide a cradle not just an outline for the tools. Picture a simple screw driver. The handle is different then the shaft. A simple blank cutout leaves the shaft unsupported and sloppy fitting in the cutout.
    A dificult one right now is a pneumatic impact gun. They are about 4" thick and i would like to provide a cradle for it, sort of a negative mold. I mention this only to show the kind of detail I would like to reach.
    Please keep the suggestions coming.
    Oct 2006
    5S Serious
    If you have the router already and run Mach3, consider looking at the Tormach Scanner as an option. If you don't need great detail just use a touch probe or even a wood dowel and use the router to pick up major dimensions.
    You could also consider sending your tools to Khalid (on Cnczone) in Pakistan for a free scan.
    A seemingly simple yet interesting project. I hope you'll share your chosen solution and some pics of the results. Cheers.
    SSSSSerious = 5S Serious
    Wanna be
    Mar 2004
    Tried something new - no luck
    At work we have a printer / scanner / copier machine so I traced out some tools onto a pc of paper and ran it through the scanner function. It ourputs a pdf file. Tried opening up the pdf file in CUT2D, but it gave me a message stating the "this file probably only contains bitmap data" and would not open the file.
    Any way around this?
    Mar 2003
    Shelby Twp, MI....USA
    A scanner can only output bitmap info. A workaround would be to save it in an image format and use a raster to vector converter on it.
    1. Need Help!- HL-8 scanning head
      By Ferrera12 in forum General Waterjet
      Last Post: 09-15-2010, 05:26 PM
    2. 3D Scanning Service
      By 3DRevEng in forum Product and Manufacturer Announcements
      Last Post: 01-29-2010, 01:45 PM
    3. digitizing vs scanning
      By xyzpro in forum Want To Buy...Need help!
      Last Post: 10-04-2009, 11:43 PM
    4. DIY 3D Scanning Options
      By MoparPogue in forum Digitizing and Laser Digitizing
      Last Post: 02-24-2007, 01:52 PM
    5. Is this the way 3d scanning will go ?
      By greybeard in forum Digitizing and Laser Digitizing
      Last Post: 02-15-2007, 12:52 PM
