Old 01-26-2008, 02:25 AM
jalessi's Avatar
jalessi jalessi is online now
jalessi is on a distinguished road
Ed,
The vendor that you purchased your system from should be able to tell you the correct settings for your (steps per) stepping ratio.
The higher the steping ratio the smoother the machine will run however it might lose torque if set to high.
Also you can slow down the velocity and the acceleration, just make sure you document the settings you started with.
I also want to mention that if your stepper motors are not aligned on the mill correctly they can bind the drive screws.
Did you check for any binding?
Jeff...
