Thread: Need Help! New engraving with CNC mill
Old 01-25-2008, 01:22 PM
bherr bherr is offline
bherr is on a distinguished road
Originally Posted by Cartierusm View Post
Sorry don't know about the software problem but as for the engraving I might be able to help. When desinging the part did you run a simulation to see if the cutter was cutting all the sections? I just did some text for a part I was making and I know nothing about envgraving nor do I have an engraving bit so I made the letters as big as I could while still being able to have a 1/4" endmill fit inside the lines. When I had the text smaller certain parts of the lettering were not getting cut because the cutter would not fit inbetween the lines. What I think is happening is the bit you're using won't fit within the size of the lettering you have desinged so the program only tries to mill out where the cutter will fit into. Right now I dealing with the same thing how to do small text without having to use a ton of specialized bits.
Cartierusm,
Know what you mean about the small letters. I think if I make the step over very small, maybe about .005 I'll be able to pick up the small sections I'm missing. when you're working with a graphic that is only 4" long and 1/25 " in height, it doesn't leave much room to play with. guess I'll just have to keep on trying different step overs until I get the results I'm looking for.
ben
