That may be one way but there is another. This one may sound strange as it does not allow for for multiple boundries.
The 'Stock Geometry' located under the 'Milling Stock' is used for a boundry in Z level machining. When set to machine all then it will machine the entire stock defined by the Stock Geometry and ignore any solid area outside of the stock geometry even if selected. |
