Old 01-24-2008, 01:06 PM
serviceman's Avatar
serviceman serviceman is offline
serviceman is on a distinguished road
Nte 22k ohm 2 % 2w 322 2w nte 78463 the resistor on this board goes bad i think its the third from the right below the pots red red orange i think. you can usually see the led light getting dimmer you can change this resistor and fix the board. if you ohm it out or look closely you will probably see cracks in it or that it is getting burned up
REYTECH Machine Service Corp. CNC repair NY, NJ
http://www.reytechmachine.com
